EddyDuo can bus Internal error on command:"ACCEPT"
Printer Model: E-Bot
MCU / Printerboard: SKR3-EZ
Hi.
I have an EddyDuo sensor connected in CAN mode, and it works well.
When I try to calibrate the temperature compensation after accepting the first calibration step (before heating), I get an error: Internal error on command:“ACCEPT”
When I switch the EddyDuo to USB mode, I get the same error again.
temperature_probe btt_eddy: calibration aborted
File “/home/biqu/klipper/klippy/gcode.py”, line 223, in _process_commands
handler(gcmd)
File “/home/biqu/klipper/klippy/gcode.py”, line 151, in
func = lambda params: origfunc(self._get_extended_params(params))
File “/home/biqu/klipper/klippy/extras/manual_probe.py”, line 243, in cmd_ACCEPT
self.finalize(True)
File “/home/biqu/klipper/klippy/extras/manual_probe.py”, line 287, in finalize
self.finalize_callback(mpresult)
File “/home/biqu/klipper/klippy/extras/temperature_probe.py”, line 240, in _manual_probe_finalize
last_temp = self._collect_sample(kin_pos, tool_zero_z)
NameError: name ‘kin_pos’ is not defined
klippy.log (544.0 KB)
Hello @Virtual77 !
At first you might update the Klipper version on the CB1:
Loaded MCU 'mcu' 137 commands (v0.13.0-513-g1fe9fb3ad / gcc: (15:12.2.rel1-1) 12.2.1 20221205 binutils: (2.40-2+18+b1) 2.40)
MCU 'mcu' config: ADC_MAX=4095 BUS_PINS_i2c1_PB6_PB7=PB6,PB7 BUS_PINS_i2c1_PB8_PB9=PB8,PB9 BUS_PINS_i2c2_PB10_PB11=PB10,PB11 BUS_PINS_i2c3_PA8_PC9=PA8,PC9 BUS_PINS_spi1=PA6,PA7,PA5 BUS_PINS_spi1a=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi2a=PC2,PC3,PB10 BUS_PINS_spi2b=PI2,PI3,PI1 BUS_PINS_spi3a=PC11,PC12,PC10 BUS_PINS_spi4=PE13,PE14,PE12 BUS_PINS_spi5=PF8,PF9,PF7 BUS_PINS_spi5a=PH7,PF11,PH6 BUS_PINS_spi6=PG12,PG14,PG13 CANBUS_BRIDGE=1 CLOCK_FREQ=520000000 MCU=stm32h723xx PWM_MAX=32768 RECEIVE_WINDOW=192 RESERVE_PINS_CAN=PB8,PB9 RESERVE_PINS_USB=PA11,PA12 RESERVE_PINS_crystal=PH0,PH1 STATS_SUMSQ_BASE=256 STEPPER_STEP_BOTH_EDGE=1
mcu 'CB1': Starting connect
Loaded MCU 'CB1' 124 commands (v0.12.0-401-g383b83d78 / gcc: (Debian 12.2.0-14) 12.2.0 binutils: (GNU Binutils for Debian) 2.40)
MCU 'CB1' config: ADC_MAX=4095 CLOCK_FREQ=50000000 MCU=linux PCA9685_MAX=4096 PWM_MAX=32768 STATS_SUMSQ_BASE=256
mcu 'eddy': Starting CAN connect
Created a socket
Loaded MCU 'eddy' 136 commands (v0.13.0-513-g1fe9fb3ad / gcc: (15:12.2.rel1-1) 12.2.1 20221205 binutils: (2.40-2+18+b1) 2.40)
MCU 'eddy' config: ADC_MAX=4095 BUS_PINS_i2c0a=gpio0,gpio1 BUS_PINS_i2c0b=gpio4,gpio5 BUS_PINS_i2c0c=gpio8,gpio9 BUS_PINS_i2c0d=gpio12,gpio13 BUS_PINS_i2c0e=gpio16,gpio17 BUS_PINS_i2c0f=gpio20,gpio21 BUS_PINS_i2c0g=gpio24,gpio25 BUS_PINS_i2c0h=gpio28,gpio29 BUS_PINS_i2c1a=gpio2,gpio3 BUS_PINS_i2c1b=gpio6,gpio7 BUS_PINS_i2c1c=gpio10,gpio11 BUS_PINS_i2c1d=gpio14,gpio15 BUS_PINS_i2c1e=gpio18,gpio19 BUS_PINS_i2c1f=gpio22,gpio23 BUS_PINS_i2c1g=gpio26,gpio27 BUS_PINS_spi0_gpio0_gpio3_gpio2=gpio0,gpio3,gpio2 BUS_PINS_spi0_gpio16_gpio19_gpio18=gpio16,gpio19,gpio18 BUS_PINS_spi0_gpio20_gpio23_gpio22=gpio20,gpio23,gpio22 BUS_PINS_spi0_gpio4_gpio3_gpio2=gpio4,gpio3,gpio2 BUS_PINS_spi0_gpio4_gpio7_gpio6=gpio4,gpio7,gpio6 BUS_PINS_spi0a=gpio0,gpio3,gpio2 BUS_PINS_spi0b=gpio4,gpio7,gpio6 BUS_PINS_spi0c=gpio16,gpio19,gpio18 BUS_PINS_spi0d=gpio20,gpio23,gpio22 BUS_PINS_spi1_gpio12_gpio11_gpio10=gpio12,gpio11,gpio10 BUS_PINS_spi1_gpio12_gpio15_gpio14=gpio12,gpio15,gpio14 BUS_PINS_spi1_gpio24_gpio27_gpio26=gpio24,gpio27,gpio26 BUS_PINS_spi1_gpio8_gpio11_gpio10=gpio8,gpio11,gpio10 BUS_PINS_spi1a=gpio8,gpio11,gpio10 BUS_PINS_spi1b=gpio12,gpio15,gpio14 BUS_PINS_spi1c=gpio24,gpio27,gpio26 CANBUS_FREQUENCY=1000000 CLOCK_FREQ=12000000 MCU=rp2040 PWM_MAX=255 RECEIVE_WINDOW=192 RESERVE_PINS_CAN=gpio4,gpio5 STATS_SUMSQ_BASE=256 STEPPER_STEP_BOTH_EDGE=1
mcu 'EBBCan': Starting CAN connect
Created a socket
Loaded MCU 'EBBCan' 136 commands (v0.13.0-513-g1fe9fb3ad / gcc: (15:12.2.rel1-1) 12.2.1 20221205 binutils: (2.40-2+18+b1) 2.40)
MCU 'EBBCan' config: ADC_MAX=4095 BUS_PINS_i2c1_PA9_PA10=PA9,PA10 BUS_PINS_i2c1_PB6_PB7=PB6,PB7 BUS_PINS_i2c1_PB8_PB9=PB8,PB9 BUS_PINS_i2c2_PA7_PA6=PA7,PA6 BUS_PINS_i2c2_PB10_PB11=PB10,PB11 BUS_PINS_i2c2_PB13_PB14=PB13,PB14 BUS_PINS_i2c3_PA7_PA6=PA7,PA6 BUS_PINS_i2c3_PB3_PB4=PB3,PB4 BUS_PINS_i2c3_PC0_PC1=PC0,PC1 BUS_PINS_spi1=PA6,PA7,PA5 BUS_PINS_spi1_PA6_PA7_PA5=PA6,PA7,PA5 BUS_PINS_spi1_PB4_PB5_PB3=PB4,PB5,PB3 BUS_PINS_spi1a=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi2_PB14_PB15_PB13=PB14,PB15,PB13 BUS_PINS_spi2_PB2_PB11_PB10=PB2,PB11,PB10 BUS_PINS_spi2_PB6_PB7_PB8=PB6,PB7,PB8 BUS_PINS_spi2_PC2_PC3_PB10=PC2,PC3,PB10 BUS_PINS_spi2a=PC2,PC3,PB10 BUS_PINS_spi3=PB4,PB5,PB3 BUS_PINS_spi3_PB4_PB5_PB3=PB4,PB5,PB3 BUS_PINS_spi3_PC11_PC12_PC10=PC11,PC12,PC10 CANBUS_FREQUENCY=1000000 CLOCK_FREQ=64000000 MCU=stm32g0b1xx PWM_MAX=32768 RECEIVE_WINDOW=192 RESERVE_PINS_CAN=PB0,PB1 RESERVE_PINS_crystal=PF0,PF1 STATS_SUMSQ_BASE=256 STEPPER_OPTIMIZED_EDGE=8 STEPPER_STEP_BOTH_EDGE=1
mcu_temperature 'eddy' nominal base=437.226612 slope=-1917.489831
Is this klippy.log an excerpt? I’m missing the startup at the beginning.
I’m attaching a new log
klippy.log (4.6 MB)
Yeah, it should be fixed soon.
Thanks,
-Timofey
Now we know that people do thermal compensation :smiley:
Fixed
How do I update Klipper to CB1?
make menuconfig
[*] Enable extra low-level configuration options
    Micro-controller Architecture (Linux process)  --->
make flash
Done.
Not strictly necessary, but it can be updated that way.
After installing version v0.13.0-515, everything on the MCU and CB1 started working. Thanks
