Klipper "Internal error on command:"PROBE_CALIBRATE""
Printer Model:
Ender 3 Pro
MCU / Printerboard:
BTT SKR 3 EZ with CR-Touch
klippy.log (328.1 KB)
Trying to do a PROBE_CALIBRATE using the following console commands:
G28
PROBE_CALIBRATE
probe at 138.000,109.000 is z=0.690500
Klipper state: Shutdown
Internal error on command:“PROBE_CALIBRATE”
Printer is shutdown
I see the following error in the klippy.log:
File “/home/pi/klipper/klippy/gcode.py”, line 198, in _process_commands
handler(gcmd)
File “/home/pi/klipper/klippy/gcode.py”, line 135, in
func = lambda params: origfunc(self._get_extended_params(params))
File “/home/pi/klipper/klippy/extras/probe.py”, line 268, in cmd_PROBE_CALIBRATE
self.probe_calibrate_finalize)
File “/home/pi/klipper/klippy/extras/manual_probe.py”, line 99, in init
self.gcode.register_command(‘NEXT’, self.cmd_ACCEPT)
File “/home/pi/klipper/klippy/gcode.py”, line 132, in register_command
“gcode command %s already registered” % (cmd,))
Error: gcode command NEXT already registered
Transition to shutdown state: Internal error on command:“PROBE_CALIBRATE”
Any idea on whether this is a hardware issue or a problem with my configuration.
I’m seeing so many configs, where people do not have a working Klipper setup yet but their configs are full of macros that they either:
  • do not understand
  • do not need
  • are from dubious sources
  • all 3 above
Something I will never understand :man_shrugging:
That having said there is a bug somewhere in your macros but I do not feel the urge to search for it. Most likely around
[gcode_macro NEXT]
gcode =
	m876 S2
Thanks for taking a look.
It’s an issue in the M600 macro that I was using. Once I got rid of that macro PROBE_CALIBRATE is working again.
The PROBE_CALIBRATE expects a typed in command at the end.
You do not have that with the LCD menu.
