Existing command 'PROBE_CALIBRATE' not found in gcode_macro rename
Printer Model: VORON 2.4
MCU / Printerboard:
installing the klicky mod, when downloading the klicky-macros.cfg file, I encountered this problem.
Existing command ‘PROBE_CALIBRATE’ not found in gcode_macro rename
Printer is halted
klippy (1).log (3.4 MB)
No log, no way to help.
uploaded, sorry I forgot)
Edited. Original post was wrong
so it’s not connected to the board? just a question, how can I connect it? I didn’t really understand what is described in the instructions and to which connector I can connect it. will the PROBE connector work? and how to specify its pins?
Never mind, I read your log wrong. I’m on mobile so I’m going to let someone else take this. I can’t effectively evaluate the log.
pic
can I use this? BTT octopus V1 board
if I attach a klicky-macros file, can you help me?
Okay, thanks for the help. I just downloaded the files from github, downloaded them practically without changing anything, and they also give an error and I’m confused what could have happened… I did everything according to the instructions in YouTube
It seems you somehow deleted your [probe] section and as such there is no command to rename
and in which of the files should it be located and where should I find it now?)
Um, honestly, no clue. It is your config and macro mess.
In previous configs (acc to your log) you had
[probe]
pin = PG15
x_offset = 0
y_offset = 25.0
z_offset = 0
speed = 10.0
samples = 3
samples_result = median
sample_retract_dist = 3.0
samples_tolerance = 0.006
samples_tolerance_retries = 3
Since you get this error there is no longer any probe defined in your config and as such Klipper does not activate the PROBE_CALIBRATE command, which leads to your error message
klippy (5).log (316.7 KB)
I do not know how, but after a couple of reboots and dancing with a tambourine, that error left me, but I got a new one) could you see what’s wrong? or is it still a problem? please, all hope is only on you)
Same reason as before, now you do not have the [bed_mesh] config section enabled and thus no BED_MESH_CALIBRATE exists that you could rename.
thank you very much! it seems everything worked out, but I didn’t really understand how to set up calibration points) but I think I’ll figure it out. thank you again for saving me!!!
