Ender 3 s1 klipper calibrate
Printer Model: ender 3 s1
MCU / Printerboard: stock of the printer
log
klippy (1).zip (794.4 KB)
hello
ender 3 s1 klipper
cant calibrate correct
one side sticking excellent one side not at all!
what to do?
in marlin works fine, only klipper doing problem… why?
Sounds like you need to level your bed.
this is what i say, i cant level correctly. always it is like this, one side good one side in the air… what to do? in marlin all works fine
How are you leveling it?
manual and abl, first manual. also z offest during print.
I would try manually tramming with the screws first, then paper test, then clear the mesh and try printing with no mesh and make sure you don’t have some kind of mechanical issue. According to your klippy.log, your bed is way out of level as there’s an almost 1.4mm difference between one corner and the opposite corner.
I installed KAMP, it helped me.
