Ender 3 S1 - No USB ID
Printer Model: Ender 3 S1 Pro
MCU / Printerboard: Creality Silent Board
klippy (1).log (158.7 KB)
Suddenly not not being able to get a USB id when running “ls /dev/serial/by-id/*” after an update
Steps tried to resolve this:
  1. Changed the USB cables
  2. Reflashed mainsailos
  3. reflashed the mcu
  4. remade the bin firmware and reflashed
  5. updated the pi
  6. sudo dmesg gives the following output
[  547.597455] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[  547.703598] usb 1-1.3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[  547.703633] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  547.703647] usb 1-1.3: Product: USB Serial
[  547.799022] usbcore: registered new interface driver usbserial_generic
[  547.799096] usbserial: USB Serial support registered for generic
[  547.805280] usbcore: registered new interface driver ch341
[  547.806438] usbserial: USB Serial support registered for ch341-uart
[  547.806601] ch341 1-1.3:1.0: ch341-uart converter detected
[  547.819231] usb 1-1.3: ch341-uart converter now attached to ttyUSB0
Atleast one other person on discord is facing the same issue.
Getting the exact same issue and followed nearly the exact same steps with no resolution.
Here is my log file as well: klippy (2).log (69.8 KB)
[ 156.649029] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
[ 156.755194] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 156.755217] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 156.755224] usb 1-1.1: Product: USB Serial
[ 156.830704] usbcore: registered new interface driver usbserial_generic
[ 156.830754] usbserial: USB Serial support registered for generic
[ 156.834698] usbcore: registered new interface driver ch341
[ 156.834750] usbserial: USB Serial support registered for ch341-uart
[ 156.834814] ch341 1-1.1:1.0: ch341-uart converter detected
[ 156.842690] usb 1-1.1: ch341-uart converter now attached to ttyUSB0
Fixed the issue by changing the following in printer.cfg
serial: /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-port0
restart_method: command
To add to this use the command "ls /dev/serial/by-path/* "
Then replace /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-port0 with the output
An even better fix was found in the Klipper discord by xF4m3 and XeroX:
In case you still have this issue after updating today, i found this fix in the voron discord klipper channel (its a pinned message there)
EDIT: Latest Debian 11 changed by intention or accident by-id and by-path mapping in systemd. This fixes the issue when klipper is not able to connect after recent update of Apr 29th 2023.
Make sure you’re root or using sudo -s before. Reboot is mandatory.
sed -i ‘/^SUBSYSTEMS==“pci”, ENV{ID_BUS}=“pci”./i SUBSYSTEMS==“usb”, IMPORT{builtin}=“usb_id”, IMPORT{builtin}=“hwdb --subsystem=usb”’ /lib/udev/rules.d/60-serial.rules
sed -i 's/^SUBSYSTEMS==“pci”, ENV{ID_BUS}=“pci”.
/SUBSYSTEMS==“pci”, ENV{ID_BUS}==“”, ENV{ID_BUS}=“pci”, \
ENV{ID_VENDOR_ID}=“$attr{vendor}”, ENV{ID_MODEL_ID}=“$attr{device}”, \
IMPORT{builtin}=“hwdb --subsystem=pci”/g’ /lib/udev/rules.d/60-serial.rules
sed -i ‘/ENV{MODALIAS}==".*/d’ /lib/udev/rules.d/60-serial.rules
The initial workaround was changing to by-path, but this does not work if you change ports. This workaround should fix it permanently and does not collide with future updates of debian.
Interesting. Thanks for sharing. Strange enough I cannot replicate:
klipper@orangepi3-lts:~$ sudo apt update
Hit:1 http://security.debian.org bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
Hit:5 http://fi.mirror.armbian.de/apt bullseye InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
klipper@orangepi3-lts:~$ cat /etc/debian_version
11.7
klipper@orangepi3-lts:~$ ls /dev/serial/by-id/*
/dev/serial/by-id/usb-Klipper_lpc1769_0C70001625813AAF86E06B5CC32000F5-if00
This solution worked for me. But I had to paste it into an editor and change all the single and double quotes as it made them special characters.
That is the reason to use
Format
when uploading code snippets
Can you please format your code with
Format
@Gre3k :smirk:
Format
not
grafik
