Ender3 V2 klipper can't connect
I am using fluidd with Ender3 V2 and few days ago, i can’t connect to local address (webpage), but only ssh.
I tried to make inet connection more stronger, and plug it in and out but it didin’t worked. What should i do?
Edit: I can’t even access to pi by ssh.
Please help me
The first thing I would do is to see if the Pi is alive on the network. You can use an app like Fing on your phone to scan all of the devices on your local network, and if the Pi is connected it will show up there. If the IP address has changed, you can either set the address as static on the Pi, or you can configure your router to always assign the same IP address to the Pi
