Printer Model: Anycubic Kobra (Klipperized as per this discourse Klipper install Anycubic kobra 2)
MCU / Printerboard: ?HC32F460?
Host / SBC: Raspberry Pi 5 (including KlipperScreen)
klippy.log (Can’t as explained below)
Normally, I have the printer set up on a Static IP.
Loaded a new filament and started doing a temperature tower as a first print, print failed on a ‘max temp exceeded’ error and I restarted the printer (firmware & host).
After the restart, I wasn’t able to connect to the printer again (using Mainsail).
Restarted the printer a couple more times with no luck.
Went into the settings and connectivity section on KlipperScreen; it is connected to my Wi-Fi, but the IP address section just shows a ‘?’… Sigh…
Thought I’d go look for it on my Wi-Fi router settings but also can’t find it.
Is there anything I can do on the KlipperScreen section to fix/troubleshoot this issue?
Thanks for your reply, I will try this in the next day or so.
No I can’t SSH with the static IP (I was able to do this before). I also cannot find the IP in my router ‘Connected Devices’ section.
Thank you for this, I will read the docs and try the suggestions.
On Option 2, I disconnected my Pi from the printer last night and carried it over to connect a LAN cable into the router - then it works fine as expected. Decided to order a long enough LAN cable to wire it in permanently (3D printer is located in the far side of my house, this isn’t the first time that Wi-Fi has been an issue).
I also tried having running a script to make my Pi mount USB drives, but no luck on that unfortunately (here is the advice I followed Google Search)
Thanks again, will report back if I find anything tonight.
