Printer is not ready The klippy host software is attempting to connect. Please retry in a few moments
my printer is not connecting to klipper.
in ssh it shows I device but in a fluid it not connecting, in fluid it says “Printer is not ready The klippy host software is attempting to connect. Please retry in a few moments”
what should I do ??
I tried changing USB cable and tried every USB port in raspberry pi
mcu 'rpi': Starting connect
mcu 'rpi': Unable to open port: [Errno 2] No such file or directory: '/tmp/klipper_host_mcu'
This issue is your rpi MCU. Run through the install process again to make sure you didn’t miss something.
https://www.klipper3d.org/RPi_microcontroller.html#install-the-rc-script
still not working, any other idea??
I have the same exact problem. I am using the Anycubic Kobra Plus, have uploaded the config file, and switched the resistor to correct the address error.
Please open a new topic according to How-To Ask for Help and provide the requested information
