Remi
March 1, 2024, 2:10pm
1
Printer Model: Voron2.4 350
MCU / Printerboard: BIGTREETECH-OCTOPUS-V1.0 Raspberry 4 Model B
moonraker (1).log (65.5 KB)
klippy.log (448.4 KB)
mcu ‘rpi’: Unable to connect
Error configuring printer
After a few minutes
Printer is not ready
The klippy host software is attempting to connect. Please
retry in a few moments.
I’ve tried all the options: updating firmware, changing cables, going through all the steps from the beginning, but nothing changes.
ls /dev/serial/by-id/*
/dev/serial/by-id/usb-Klipper_stm32f446xx_2E0003001150324E31333220-if00
Hello @Remi !
The issue is not your printer board, it’s your secondary mcu:
mcu 'rpi': Unable to open port: [Errno 2] No such file or directory: '/tmp/klipper_host_mcu'
Take care to not mix up the identifier:
Try:
[mcu host]
serial = /tmp/klipper_host_mcu
Have you setup the additional code?
https://www.klipper3d.org/RPi_microcontroller.html
Remi
March 1, 2024, 3:16pm
3
pi@mainsailos:~ $ cd ~/klipper/
sudo cp ./scripts/klipper-mcu.service /etc/systemd/system/
sudo systemctl enable klipper-mcu.service
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for pi:
Created symlink /etc/systemd/system/multi-user.target.wants/klipper-mcu.service → /etc/systemd/system/klipper-mcu.service.
pi@mainsailos:~/klipper $ cd ~/klipper/
make menuconfig
Using default symbol values (no ‘/home/pi/klipper/.config’)
Configuration saved to ‘/home/pi/klipper/.config’
Creating symbolic link out/board
Loaded configuration ‘/home/pi/klipper/.config’
pi@mainsailos:~/klipper $ sudo service klipper stop
make flash
sudo service klipper start
Building out/autoconf.h
Compiling out/src/sched.o
Compiling out/src/command.o
Compiling out/src/basecmd.o
Compiling out/src/debugcmds.o
Compiling out/src/initial_pins.o
Compiling out/src/gpiocmds.o
Compiling out/src/stepper.o
Compiling out/src/endstop.o
Compiling out/src/trsync.o
Compiling out/src/adccmds.o
Compiling out/src/spicmds.o
Compiling out/src/sdiocmds.o
Compiling out/src/i2ccmds.o
Compiling out/src/pwmcmds.o
Compiling out/src/buttons.o
Compiling out/src/tmcuart.o
Compiling out/src/neopixel.o
Compiling out/src/pulse_counter.o
Compiling out/src/lcd_st7920.o
Compiling out/src/lcd_hd44780.o
Compiling out/src/spi_software.o
Compiling out/src/i2c_software.o
Compiling out/src/thermocouple.o
Compiling out/src/sensor_adxl345.o
Compiling out/src/sensor_angle.o
Compiling out/src/sensor_mpu9250.o
Compiling out/src/sensor_lis2dw.o
Compiling out/src/sensor_bulk.o
Compiling out/src/stm32/watchdog.o
Compiling out/src/stm32/gpio.o
Compiling out/src/stm32/clockline.o
Compiling out/src/stm32/dfu_reboot.o
Compiling out/src/generic/crc16_ccitt.o
Compiling out/src/generic/armcm_boot.o
Compiling out/src/generic/armcm_irq.o
Compiling out/src/generic/armcm_reset.o
Compiling out/src/…/lib/stm32f4/system_stm32f4xx.o
Compiling out/src/stm32/stm32f4.o
Compiling out/src/generic/armcm_timer.o
Compiling out/src/stm32/gpioperiph.o
Compiling out/src/stm32/adc.o
Compiling out/src/stm32/i2c.o
Compiling out/src/stm32/spi.o
Compiling out/src/stm32/sdio.o
Compiling out/src/stm32/usbotg.o
Compiling out/src/stm32/chipid.o
Compiling out/src/generic/usb_cdc.o
Compiling out/src/stm32/hard_pwm.o
Building out/compile_time_request.o
Version: v0.12.0-114-ga77d0790
Preprocessing out/src/generic/armcm_link.ld
Linking out/klipper.elf
Creating hex file out/klipper.bin
Building hid-flash
gcc -c -Wall -std=gnu99 -I . pkg-config libusb-1.0 --cflags main.c -o main.o
gcc -c -Wall -std=gnu99 -I . pkg-config libusb-1.0 --cflags hid-libusb.c -o hid-libusb.o
gcc -c -Wall -std=gnu99 -I . pkg-config libusb-1.0 --cflags rs232.c -o rs232.o
gcc -no-pie main.o hid-libusb.o rs232.o pkg-config libusb-1.0 --libs -lrt -lpthread -o hid-flash
Flashing out/klipper.bin to
Please specify FLASH_DEVICE
make: *** [src/stm32/Makefile:111: flash] Error 255
Sineos
March 1, 2024, 3:26pm
4
Remi:
Error 255
Please do not post just some fragment from which nobody sees what command you have issued and what has happened before the error
Edit:
It just looks like you issued a wrong / not applicable make flash command that is not covered under the relevant documentation.
