Mcu 'rpi': Unable to open port: [Errno 2] No such file or directory: '/tmp/klipper_host_mcu'
Printer Model: Ender 3 Pro
I am trying to use rpi as second controller. I used the guide : RPi microcontroller - Klipper documentation
I keep getting the error :
“mcu ‘rpi’: Unable to open port: [Errno 2] No such file or directory: ‘/tmp/klipper_host_mcu’”
I checked the /tmp folder and do not see the file there.
klippy.log (3.0 MB)
Hi. Have you rebooted since you set up the klipper-mcu service? If not, check if the service is running:
service klipper-mcu status
If this returns anything else than “active”, try:
service klipper-mcu start
The klipper-mcu service needs to be running, otherwise you get a connection error.
If the klipper-mcu service doesn’t autostart at boot, rerun the systemclt command in the guide.
