Background
The klipper-mcu process fails to start on certain Linux distributions, even when the relevant documentation is carefully followed.
This issue primarily affects Armbian Linux distributions or those based on Armbian.
Diagnosing the issue
The easiest way to recognize this problem is in the klippy.log where an error message like
mcu 'rpi': Unable to open port: [Errno 2] No such file or directory: '/tmp/klipper_host_mcu'
will appear.
Further issuing the command:
systemctl status klipper-mcu
yields following result:
klipper@bigtreetech-cb1:~# systemctl status klipper-mcu
β klipper-mcu.service - Starts the MCU Linux firmware for klipper on startup
Loaded: loaded (/etc/systemd/system/klipper-mcu.service; enabled; preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2023-12-11 19:39:56 CET; 4s ago
Docs: https://www.klipper3d.org/RPi_microcontroller.html
Process: 2408 ExecStart=/usr/local/bin/klipper_mcu -r -I ${KLIPPER_HOST_MCU_SERIAL} (code=exited, status=255/EXCEPTION)
Main PID: 2408 (code=exited, status=255/EXCEPTION)
CPU: 6ms
and finally, the commands:
sudo service klipper-mcu restart
# Wait around 30 seconds before issueing the following command:
sudo journalctl -u klipper-mcu
Produces following output:
Dec 11 19:17:48 cb1 systemd[1]: Started klipper-mcu.service - Starts the MCU Linux firmware for klipper on startup.
Dec 11 19:24:47 cb1 systemd[1]: Stopping klipper-mcu.service - Starts the MCU Linux firmware for klipper on startup...
Dec 11 19:24:48 cb1 systemd[1]: klipper-mcu.service: Deactivated successfully.
Dec 11 19:24:48 cb1 systemd[1]: Stopped klipper-mcu.service - Starts the MCU Linux firmware for klipper on startup.
Dec 11 19:24:48 cb1 systemd[1]: Started klipper-mcu.service - Starts the MCU Linux firmware for klipper on startup.
Dec 11 19:24:48 cb1 klipper_mcu[1934]: Got error -1 in sched_setscheduler: (1)Operation not permitted
Dec 11 19:24:48 cb1 systemd[1]: klipper-mcu.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 11 19:24:48 cb1 systemd[1]: klipper-mcu.service: Failed with result 'exit-code'.
Dec 11 19:24:53 cb1 systemd[1]: klipper-mcu.service: Scheduled restart job, restart counter is at 1.
Dec 11 19:24:53 cb1 systemd[1]: Stopped klipper-mcu.service - Starts the MCU Linux firmware for klipper on startup.
Dec 11 19:24:53 cb1 systemd[1]: Started klipper-mcu.service - Starts the MCU Linux firmware for klipper on startup.
Dec 11 19:24:53 cb1 klipper_mcu[1937]: Got error -1 in sched_setscheduler: (1)Operation not permitted
The key error message here is:
Reason for the error
To achieve highly precise timing, the klipper_mcu is operated in real-time mode. However, the kernel of these distributions requires Real-Time Group Scheduling, which is incompatible with systemd and causes relevant calls to fail.
Temporary Fix
To test the solution, a temporary fix can be deployed by issuing the command:
sudo sysctl -w kernel.sched_rt_runtime_us=-1
If now the service starts successfully, which can be again verified with systemctl status klipper-mcu, the fix can be made permanent.
Permanent Fix
Adjusting kernel parameters should only be done after confirming that this approach effectively solves the problem. Run the following command to make the changes permanent:
echo "kernel.sched_rt_runtime_us = -1" | sudo tee /etc/sysctl.d/10-disable-rt-group-limit.conf
# Now reboot the system to verify
sudo reboot now
Credits go to @Piezo for this fix.
