Printer is not ready The klippy host software is attempting to connect
Basic Information: Cannot connect K2 Neo to Klipper
Printer Model: Anycubic Kobra 2 Neo
MCU / Printerboard: Huada semiconductor hc32f460
klippy.log (254.2 KB)
Describe your issue: First time installing Klipper. I’ve gone through all the errors that Mainsail provided. I’m stuck on this mcu error. Looking for help. I haven’t found much for installing Klipper on the K2 Neo
klippy (1).log (272.9 KB)
Sineos edit: Unnecessary stuff
Have you checked your USB cable and make sure it is good for data transfer? and have you done the mode on your USB A cable to eliminate 5V as per link below. Put tape on the 5V pin - Why and how - FAQ - OctoPrint Community Forum
I cannot garantee that this will fix the problem, but that would be my first stop to explore.
Data cable is good. I haven’t messed with any of the connections on the board.
Ok, did you updated/confirm the mcu serial in printer.cfg? and did you confirm the usb id/path on you board?
@Scootster :
Please: Either upload your code as a file or use the Preformatted Text feature of the forum editor to make it more readable:
Format
Experience has shown that this is often a rather daring statement. In any case, the typical reasons for your issue are listed here: Issues flashing the printer board
