Installation issue
Printer Model: voron 2.4R
I have made a fresh install, but get only this - what can be the problem ?
mcu 'mcu': Unable to connect
Error configuring printer
klippy-5.log (202.1 KB)
moonraker-2.log (186.4 KB)
Try a different USB cable.
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/usb-Klipper_stm32f446xx_1F0037000851313133353932-if00: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-Klipper_stm32f446xx_1F0037000851313133353932-if00'
Is that ID correct? SSH in and run ls /dev/serial/by-id/*.
@orge70
For better understanding see How-To Trouble-Shoot
