Unable to get printer to connect to klipper
Printer Model: ender 3
MCU / Printerboard:skr mini e3 v3
Host / SBC: ubuntu desktop
klippy.log (35.6 KB)
…unable to connect to klippy after canceling printand am also unable to upload the klippy.log file, gives an error of flie not available on site
How did you install Klipper to Ubuntu?
Search on the HDD, SSD, partitions or whatever you have on your ubuntu desktop. There must be a klippy.log and that is mandatory to give you any hint/help.
installed klipper using kiauh
i found the klippy.log
Is the printer properly connected to the desktop?
Are you using a virtual environment?
yes its properly connected and its a dedicated machine so no virtual env.
How did you determine
serial = /dev/serial/by-id/usb-Klipper_stm32g0b0xx_500046001450415833323520-if00
The klippy.log is basically very clear (Split into two lines for better readability):
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/usb-Klipper_stm32g0b0xx_500046001450415833323520-if00:
[Errno 2] No such file or directory: '/dev/serial/by-id/usb-Klipper_stm32g0b0xx_500046001450415833323520-if00'
No such file or directory means exactly this: This path does not exists and so Klipper cannot connect to it.
Follow the setup procedure, e.g. Installing Klipper with KIAUH and determine the correct path. If nothing turns up, then probably the board is not correctly flashed. Issues flashing the printer board gives some more hints in such a case.
What do you mean how did I determine?? Determine what??
I have already tried to reinstall klipper and reflashed the mainboard
I got the MCU path from kiauh if that’s what you mean
any idea on how to fix that?
Post the output of
ls /dev/serial/by-id/*
This must macht with your
serial: ...
statement. Klipper’s error message clearly shows that it doesn’t match.
If not follow the two links I posted above, in particular the second one if you have a running setup already.
it does match as far as i can tell
Well, this seems quite strange and you should carefully review the situation.
The Klipper error message is not generated by Klipper itself but by the underlying Linux OS and tells you that the given path in:
cannot be accessed because it simply does not exist.
If now the command ls /dev/serial/by-id/* (also a Linux OS command) returns exactly the very same path but the SAME error message in your log persists, then we have a contradiction.
I have not seen a single case where this would have been true.
the ls /dev/serial/by-id/* output was the same as the [mcu] serial = /dev/serial/by-id/usb-Klipper_stm32g0b0xx_500046001450415833323520-if00
idk what the issue was with it. I just ended up installing debian and reinstalled klipper and reflashed the printer
