My printer refuses to connect
Printer Model: Ender 3
MCU / Printerboard:Silent 4.2.7
Host / SBC:Dont know what this means?
klippy(6).log (18.6 KB)
… My printer refuses to connect no matter what, i tried building the firmware a couple of times but with no luck. Just says: “mcu ‘mcu’: Unable to connect
Error configuring printer”. The printer does connect as a serial port to my pc. Any ideas?
Hello @Zynthrodak !
Have you tried different USB cables?
Where is Klipper running on (SBC: Single Board Computer)
I’ve tried 2 cables, im running klipper on some old laptop on linux mint. The laptop detects the printer as a device
How did you get Klipper on the laptop?
Was Kiauh able to flash the MCU via SD card??
Yep, i got the file, put it on my sd and plugged it in and waited. But the serial output looks wonky? I tried every baud rate and it still looks like random characters
There are quite a few potential contributors to this problem. See Issues flashing the printer board
