Printer Model: Creality CR-10S
MCU / Printerboard: BTT SKR 1.4 Turbo and Raspberry Pi 3
klippy.log (8.8 KB)
I cannot seem to connect to my printer anymore after I reinstalled my Raspberry pi 3. Config files worked fine before reinstallation, but unfortunately I had to reinstall due to failing SD card. The printer used to work flawlessly but unfortunately the pi didn’t boot anymore. I was able to get the config files from the broken SD card, so they are identical to the previously working files.
I have installed Klipper, Moonraker and KlipperScreen through KIAUH, the system is up to date.
Logfile is incomplete, the following lines showed up later:
Got EOF when reading from device
Timeout with MCU 'mcu' (eventtime=1758.578716)
Please help!
klippy.log.txt (164.3 KB)
Sineos
November 27, 2022, 6:06pm
2
Please attach a klippy.log showing the issue.
Sineos
November 27, 2022, 6:38pm
4
Got EOF when reading from device strictly speaking is not a Klipper error.
This means that the Linux operating system on your host has an issue with a USB device, in this case your MCU.
You can use sudo dmesg to check for USB relevant error messages. Most likely some hardware thing:
bad USB cable
bad USB connectors
other hardware defects
dmesg does not report any errors
[11007.033959] usb 1-1.3: new full-speed USB device number 9 using dwc_otg
[11007.168542] usb 1-1.3: New USB device found, idVendor=1d50, idProduct=614e, bcdDevice= 1.00
[11007.168567] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[11007.168578] usb 1-1.3: Product: lpc1769
[11007.168587] usb 1-1.3: Manufacturer: Klipper
[11007.168595] usb 1-1.3: SerialNumber: 1680FF1880A037AF43E8BF5BC02000F5
[11007.169920] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
I have exchanged the USB cable for a different one, but to no avail.
In moonraker.log, I see the following recurring error:
2022-11-27 20:36:19,797 [websockets.py:build_error()] - JSON-RPC Request Error: -32601
Method not found
The issue has been resolved!
Apparently my re-installation was on another dying SD-card. A brand new SD card with another complete re-install solved the issue!
Unfortunately, I was happy too early. I’ve had two succesful prints, turned off the printer, turned it on again and it doesn’t want to connect anymore. Klippy.log is filled with the following lines:
Stats 65.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=5 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.66 cputime=3.942 memavail=769944 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 66.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=7 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.66 cputime=3.975 memavail=769944 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 67.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=8 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.66 cputime=3.997 memavail=769692 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 68.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=9 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.66 cputime=4.020 memavail=769704 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 69.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=10 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.66 cputime=4.043 memavail=769704 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 70.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=11 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.77 cputime=4.065 memavail=769704 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 71.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=12 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.77 cputime=4.088 memavail=769704 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 72.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=13 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.77 cputime=4.111 memavail=769704 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 73.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=14 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.77 cputime=4.133 memavail=769704 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 74.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=15 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.77 cputime=4.156 memavail=769704 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 75.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=16 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.78 cputime=4.178 memavail=769704 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 76.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=17 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.78 cputime=4.201 memavail=769256 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 77.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=18 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.78 cputime=4.224 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 78.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=19 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.78 cputime=4.246 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 79.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=21 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.78 cputime=4.268 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 80.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=22 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.80 cputime=4.291 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 81.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=23 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.80 cputime=4.313 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 82.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=24 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.80 cputime=4.335 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 83.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=25 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.80 cputime=4.358 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 84.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=26 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.80 cputime=4.380 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 85.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=27 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.74 cputime=4.402 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 86.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=28 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.74 cputime=4.425 memavail=768252 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 87.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=29 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.74 cputime=4.447 memavail=767496 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 88.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=30 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.74 cputime=4.470 memavail=767504 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 89.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=31 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.74 cputime=4.492 memavail=767564 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 90.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=32 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.68 cputime=4.509 memavail=767524 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 91.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=33 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.68 cputime=4.532 memavail=767524 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 92.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=34 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.68 cputime=4.555 memavail=767524 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 93.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=35 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.68 cputime=4.573 memavail=765808 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 94.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=36 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.68 cputime=4.586 memavail=765008 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 95.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=37 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.62 cputime=4.608 memavail=765008 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 96.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=38 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.62 cputime=4.631 memavail=765008 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 97.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=39 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.62 cputime=4.654 memavail=764504 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 98.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=40 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.62 cputime=4.677 memavail=764520 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 99.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=41 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.62 cputime=4.699 memavail=764520 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 100.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=42 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.65 cputime=4.722 memavail=764520 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 101.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=43 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.65 cputime=4.745 memavail=764520 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 102.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=44 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.65 cputime=4.768 memavail=764520 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Stats 103.7: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000007 mcu_task_stddev=0.000006 bytes_write=7730 bytes_read=7494 bytes_retransmit=9 bytes_invalid=0 send_seq=342 receive_seq=342 retransmit_seq=2 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=45 freq=119996566 heater_bed: target=0 temp=17.8 pwm=0.000 sysload=0.65 cputime=4.791 memavail=764520 print_time=0.019 buffer_time=0.000 print_stall=0 extruder: target=0 temp=17.6 pwm=0.000
Now what?
I tried to upload my klippy.log but unfortunately it doesn’t seem to want to do that.
Sineos
December 1, 2022, 9:13am
9
We will need the klippy.log, upload e.g. zipped. From the snippet as posted nothing can be seen.
klippy.log.zip (1.0 MB)
I apologize for the delayed response, please find my klippy.log attached.
Since I managed to print 2 succesful prints, I suppose my hardware should be okay…
klippy(3).log (37.4 KB)
Here is another klippy.log, from my test today. Printer is turned on, klippy doesn’t want to connect. I attempted 2 times.
One thing I noticed is that the connection of Klipper/Moonraker to my TP Link plug did not work when my prints were running. After a reboot, they work, but then my klipper stopped working. I tried removing the connection with the TP link plug but to no avail.
Sineos
December 3, 2022, 8:09am
11
I’m not sure what you are reporting.
The klippy(3).log above does not contain any Klipper errors. On the contrary, it shows a successful start.
As for the zipped log and the EOF error there is not much more to say about unfortunately: Your host’s Linux is reporting that the data stream from the MCU is gone.
This usually is a hardware issue. I’m almost 105% sure that this is not any Klipper issue, since
your setup is nothing special
BTT SKR 1.4 is common board
I’m running it in one of my printers as well since years on different host platform, e.g. RPI3, OPi 3 LTS and currently on a Tinkerboard
As you found out, even a dying SD card can cause such issues. This means such things are quite hard to debug since this error message gives no clue as to the why.
You can use the command
sudo dmesg -wH
to permanently monitor the Kernel buffer. If you start a print now and get an EOF and you see anything in the dmesg out relating to USB then you have yet another indication.
That’s unfortunate… My Fluidd interface keeps reporting “Klippy is not connected” and I cannot do anything, let alone start a print…
Sineos
December 3, 2022, 9:50am
13
Provide the output of
cat /etc/default/klipper
and
cat /etc/systemd/system/klipper.service
cat: /etc/default/klipper: No such file or directory
[Unit]
Description=Klipper 3D Printer Firmware SV1
Documentation=https://www.klipper3d.org/
After=network-online.target
Wants=udev.target
[Install]
WantedBy=multi-user.target
[Service]
Type=simple
User=pi
RemainAfterExit=yes
WorkingDirectory=/home/pi/klipper
EnvironmentFile=/home/pi/printer_data/systemd/klipper.env
ExecStart=/home/pi/klippy-env/bin/python $KLIPPER_ARGS
Restart=always
RestartSec=10
Sineos
December 3, 2022, 9:56am
15
and:
cat /home/pi/printer_data/systemd/klipper.env
KLIPPER_ARGS="/home/pi/klipper/klippy/klippy.py /home/pi/printer_data/config/printer.cfg -I /home/pi/printer_data/comms/klippy.serial -l /home/pi/printer_data/logs/klippy.log -a /home/pi/printer_data/comms/klippy.sock"pi@klipper:/etc/default $
Hey, that seemed to solve the issue, I can connect to the printer again! Would you mind explaining what that edit did exactly?
So if I understand correctly, the connection between klipper and moonraker was faulty, not the connection between moonraker and my printer? Interesting
Thanks a lot!
