Printer Model: flsunv400
MCU / Printerboard:mks skipr
no log
Having trouble connecting to printer from mainsail ip address. Was working and installed a mks ips50 screen and am now not able to connect. Reloaded everything using kiauh and still nothing. Checked printer config and everything to have set to the printers ip but still no connect. Any help on placed to check or if I’m doing something obviously wrong . Board is brand new and doing initial setup
Hello @Jpierce !
Can you please tell us more on what system you have installed Klipper?
hcet14
June 15, 2023, 7:03pm
3
Do you have an old klippy.log?
Good luck, hcet14
Sineos
June 15, 2023, 7:05pm
4
Post your moonraker.log, please
Sorry yes running klipper, moonraker and mainsail
Ok, but I asked for the hardware.
The hardware is a Makerbase skipr board installed in a flsun v400 with an Makerbase ips50 screen
And where does Klipper run on?
Klipper is running on the skipr board, I am able to control klipper screen on the small screen via hdmi
hcet14
June 16, 2023, 3:12pm
10
And what is your host machine?
What do you mean host machine? There’s nothing else besides my computer connected
hcet14
June 16, 2023, 4:11pm
13
Could you give a lot more information?
What OS is running on your PC connected to MKS-SKIPR
How is the MKS-SKIPR connected to the PC
etc.
My pc is on windows 10 and connected through lan cable from router and computer is wired to router
Armblan 22.05.0-trunk with bleeding edge Linux 5.16.20-rockchipss
This is what’s running on the chip
Sorry I’m a bit new to getting a new board setup
hcet14
June 16, 2023, 6:01pm
15
Like this?
Me too. Are you able to connect to your SOC on MKS-SKIPR using SSH?
I’m able to connect via ssh no problem
hcet14
June 16, 2023, 7:02pm
17
good
When it was working, do you still have an old klippy.log?
Just reflashed the emmc with new image and now works. Should have tried from the start but thank you guys for the help it’s much appreciated
