I killed my board and now have a new one, but I cannot get the endstop switches to work.
Or rather, I can, but only by wiring them up the other way.
The board has 3 pins for each: +5V, Ground and signal. They work if I connect them between signal and ground, but don’t from +5V to ground, no matter what I’ve tried setting in the printer.cfg
That said, I have not found the clear instructions, so it is quite likely that I haven’t set the right thing there…
Board is a MKS SGEN-L
