Error MCU 'mcu' shutdown: Timer too close
Printer Model: ender3
MCU / Printerboard: 4.2.2
Host / SBC virtualbox on rpi os
klippy.log 31e2db077faeee2bda8d48c3e0127ede.log (874.8 KB)
MCU ‘mcu’ shutdown: Timer too close
This often indicates the host computer is overloaded. Check
for other processes consuming excessive CPU time, high swap
usage, disk errors, overheating, unstable voltage, or
similar system problems on the host computer.
Printer is shutdown
Please review these results before continuing to post to this discussion; thanks.
https://klipper.discourse.group/search?context=topic&context_id=17048&q=Timer%20too%20close&skip_context=true
