i am facing such a problem when i send my printer home. I’m new to Klipper. The problem is:
MCU ‘mcu’ shutdown: Timer too close
This often indicates the host computer is overloaded. Check
for other processes consuming excessive CPU time, high swap
usage, disk errors, overheating, unstable voltage, or
similar system problems on the host computer.
Printer is shutdown
