Error when compiling
MCU / Printerboard : STM32F103C8T6 blue pill
I’m trying to compile klipper for an STM32F103C8T6 (I know it’s old so I’m probably having problems compiling it)
I’ll leave it here in the meantime I’ll continue investigating
###### Initializing firmware build ...
###### Checking for the following dependencies:
● build-essential
● dpkg-dev
● make
[✓ OK] Dependencies already met!
###### Building firmware ...
  Creating symbolic link out/board
Loaded configuration '/home/mago/klipper/.config'
No changes to save (for '/home/mago/klipper/.config')
  Building out/autoconf.h
  Compiling out/src/sched.o
  Compiling out/src/command.o
  Compiling out/src/basecmd.o
  Compiling out/src/debugcmds.o
  Compiling out/src/initial_pins.o
  Compiling out/src/gpiocmds.o
  Compiling out/src/stepper.o
  Compiling out/src/endstop.o
  Compiling out/src/trsync.o
  Compiling out/src/adccmds.o
  Compiling out/src/spicmds.o
  Compiling out/src/i2ccmds.o
  Compiling out/src/pwmcmds.o
  Compiling out/src/buttons.o
  Compiling out/src/tmcuart.o
  Compiling out/src/neopixel.o
  Compiling out/src/pulse_counter.o
  Compiling out/src/lcd_st7920.o
  Compiling out/src/lcd_hd44780.o
  Compiling out/src/spi_software.o
  Compiling out/src/i2c_software.o
  Compiling out/src/thermocouple.o
  Compiling out/src/sensor_adxl345.o
  Compiling out/src/sensor_angle.o
  Compiling out/src/sensor_mpu9250.o
  Compiling out/src/sensor_lis2dw.o
  Compiling out/src/sensor_ldc1612.o
  Compiling out/src/sensor_bulk.o
  Compiling out/src/stm32/watchdog.o
  Compiling out/src/stm32/gpio.o
  Compiling out/src/stm32/clockline.o
  Compiling out/src/stm32/dfu_reboot.o
  Compiling out/src/generic/crc16_ccitt.o
  Compiling out/src/generic/armcm_boot.o
  Compiling out/src/generic/armcm_irq.o
  Compiling out/src/generic/armcm_reset.o
  Compiling out/src/../lib/stm32f1/system_stm32f1xx.o
  Compiling out/src/stm32/adc.o
  Compiling out/src/stm32/stm32f1.o
  Compiling out/src/generic/armcm_timer.o
  Compiling out/src/stm32/i2c.o
  Compiling out/src/stm32/spi.o
  Compiling out/src/stm32/usbfs.o
  Compiling out/src/stm32/chipid.o
  Compiling out/src/generic/usb_cdc.o
  Compiling out/src/stm32/hard_pwm.o
  Building out/compile_time_request.o
Version: v0.12.0-208-g49c0ad63
  Preprocessing out/src/generic/armcm_link.ld
  Linking out/klipper.elf
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-closer.o): in function `_close_r':
/build/newlib-38V0JC/newlib-4.4.0.20231231/build_nano/arm-none-eabi/thumb/v7-m/nofp/newlib/../../../../../../newlib/libc/reent/closer.c:47:(.text+0xc): warning: _close is not implemented and will always fail
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-closer.o): note: the message above does not take linker garbage collection into account
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-signalr.o): in function `_getpid_r':
/build/newlib-38V0JC/newlib-4.4.0.20231231/build_nano/arm-none-eabi/thumb/v7-m/nofp/newlib/../../../../../../newlib/libc/reent/signalr.c:83:(.text+0x28): warning: _getpid is not implemented and will always fail
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-signalr.o): note: the message above does not take linker garbage collection into account
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-signalr.o): in function `_kill_r':
/build/newlib-38V0JC/newlib-4.4.0.20231231/build_nano/arm-none-eabi/thumb/v7-m/nofp/newlib/../../../../../../newlib/libc/reent/signalr.c:53:(.text+0xe): warning: _kill is not implemented and will always fail
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-lseekr.o): in function `_lseek_r':
/build/newlib-38V0JC/newlib-4.4.0.20231231/build_nano/arm-none-eabi/thumb/v7-m/nofp/newlib/../../../../../../newlib/libc/reent/lseekr.c:49:(.text+0x14): warning: _lseek is not implemented and will always fail
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-lseekr.o): note: the message above does not take linker garbage collection into account
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-readr.o): in function `_read_r':
/build/newlib-38V0JC/newlib-4.4.0.20231231/build_nano/arm-none-eabi/thumb/v7-m/nofp/newlib/../../../../../../newlib/libc/reent/readr.c:49:(.text+0x14): warning: _read is not implemented and will always fail
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-readr.o): note: the message above does not take linker garbage collection into account
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-writer.o): in function `_write_r':
/build/newlib-38V0JC/newlib-4.4.0.20231231/build_nano/arm-none-eabi/thumb/v7-m/nofp/newlib/../../../../../../newlib/libc/reent/writer.c:49:(.text+0x14): warning: _write is not implemented and will always fail
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/lib/thumb/v7-m/nofp/libg_nano.a(libc_a-writer.o): note: the message above does not take linker garbage collection into account
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/13.2.1/thumb/v7-m/nofp/libgcc.a(unwind-arm.o): in function `get_eit_entry':
/build/gcc-arm-none-eabi-TuTZN0/gcc-arm-none-eabi-13.2.rel1/build/arm-none-eabi/thumb/v7-m/nofp/libgcc/../../../../../../libgcc/unwind-arm-common.inc:366:(.text+0x130): undefined reference to `__exidx_start'
/usr/lib/gcc/arm-none-eabi/13.2.1/../../../arm-none-eabi/bin/ld: /build/gcc-arm-none-eabi-TuTZN0/gcc-arm-none-eabi-13.2.rel1/build/arm-none-eabi/thumb/v7-m/nofp/libgcc/../../../../../../libgcc/unwind-arm-common.inc:366:(.text+0x134): undefined reference to `__exidx_end'
collect2: error: ld returned 1 exit status
make: *** [Makefile:73: out/klipper.elf] Error 1
See Fix build on recent arm gcc/newlibc versions by KevinOConnor · Pull Request #6615 · Klipper3d/klipper · GitHub
Sorry but I don’t know how to replace what it says in the forum…
The issue is caused by newer versions of GCC and newlibc that certain distributions started shipping, e.g. Ubuntu 24.04.
Either you switch back to an older / working Linux version, e.g. Debian Bookworm, or you wait some days until this is merged.
You can also pick this PR branch, but this requires some git understanding:
git fetch origin pull/6615/head:pr-6615
git checkout pr-6615
to pull these modification. And then to revert back at a later stage:
git checkout master
git branch -D pr-6615
