Failing to flash Ender3 v2
Is there any output I should expect from the printer on successful flash aside from it showing up in klipper?
I’ve also tried flashing the firmware binary found {here}(Support for new Creality boards 4.2.2 with GD32F303 - #30 by d00vy) but it doesn’t seem to work. I’ve tried with and without the LCD plugged in also.
Nothing shows up when I run ls /dev/serial/by-id/*
