Flashing Klipper on stock Ender-3
Printer Model: Ender-3
MCU / Printerboard: Creality 4.2.2 with GD32F303
Host / SBC: Antix running Octoprint
klippy.log: not updating, but added below anyway
Starting Klippy...
Args: ['/home/octoprint/klipper/klippy/klippy.py', '/home/octoprint/printer_data/config/printer.cfg', '-I', '/home/octoprint/printer_data/comms/klippy.serial', '-l', '/home/octoprint/printer_data/logs/klippy.log', '-a', '/home/octoprint/printer_data/comms/klippy.sock']
Git version: 'v0.12.0-410-gcf3b0475d'
Branch: master
Remote: origin
Tracked URL: https://github.com/Klipper3d/klipper
CPU: 2 core Intel(R) Pentium(R) Dual  CPU  T3400  @ 2.16GHz
Python: '3.11.2 (main, Aug 26 2024, 07:20:54) [GCC 12.2.0]'
Building C code module c_helper.so
Start printer at Sat Jan 18 19:40:48 2025 (1737229248.3 1833.7)
===== Config file =====
serial = /dev/serial/by-id/<your-mcu-id>
[virtual_sdcard]
path = /home/octoprint/printer_data/gcodes
on_error_gcode = CANCEL_PRINT
[printer]
kinematics = none
max_velocity = 1000
max_accel = 1000
mcu 'mcu': Starting serial connect
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/<your-mcu-id>: [Errno 2] No such file or directory: '/dev/serial/by-id/<your-mcu-id>'
MCU error during connect
  File "/home/octoprint/klipper/klippy/mcu.py", line 793, in _mcu_identify
    self._serial.connect_uart(self._serialport, self._baud, rts)
  File "/home/octoprint/klipper/klippy/serialhdl.py", line 183, in connect_uart
    self._error("Unable to connect")
  File "/home/octoprint/klipper/klippy/serialhdl.py", line 61, in _error
serialhdl.error: mcu 'mcu': Unable to connect
  File "/home/octoprint/klipper/klippy/klippy.py", line 131, in _connect
    self.send_event("klippy:mcu_identify")
  File "/home/octoprint/klipper/klippy/klippy.py", line 223, in send_event
    return [cb(*params) for cb in self.event_handlers.get(event, [])]
  File "/home/octoprint/klipper/klippy/klippy.py", line 223, in <listcomp>
  File "/home/octoprint/klipper/klippy/mcu.py", line 798, in _mcu_identify
    raise error(str(e))
mcu.error: mcu 'mcu': Unable to connect
Error configuring printer
No build file /home/octoprint/klipper/klippy/../.config
No build file /home/octoprint/klipper/klippy/../out/klipper.dict
No build file /home/octoprint/klipper/klippy/../out/klipper.elf
I have tried all the suggestions on here and I still can’t get connected.
Octoprint has been running great and I had a recent version Marlin firmware flashed on my printer, and I can reflash that firmware with no problems. Not sure if the Klipper is even flashing as the screen stays blank and octoprint just says
Klipper: Standby and in terminal I only get:
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /home/octoprint/printer_data/comms/klippy.serial, baudrate 250000
Hello @Alf-Tupper !
Please always upload the complete klippy.log !
And at least use the Preformattet Text feature of the forum editor instead of Blockquote.for code.
Format
Hey @EddyMI3D - Thanks for letting me know. I have updated my post.
Regarding the log I cant get it to update, not sure if its a separate issue or would start to update once klipper connects.
You don’t have a serial ID for your printer defined:
https://www.klipper3d.org/Installation.html#building-and-flashing-the-micro-controller
Hi, I have got this connected… Its showing like that on the log as its not updating for some reason
Please see attached screenshots.
