Who can help me get klipper working on my ender 3v2 :(
Ender 3v2 (4.2.2 Board) - Klipper Serial Connection Failures Despite Correct Setup
Hardware:
  • Ender 3v2 (4.2.2 board)
  • Raspberry Pi 3 (64-bit Lite OS, headless)
  • OctoPrint partially connects, Klipper fails
Attempts:
  1. Firmware:
    • Built with STM32F103, 28KiB bootloader, 8MHz crystal, USART1 PA10/PA9.
    • Re-flashed via SD card (FAT32/4096 block) with unique filenames (e.g., firmware-2024.bin).
    • Successfully flashed Marlin previously (confirms SD card works).
  2. Config:
    • printer.cfg based on the one from github
    • Tested all diferent sorts of baud rates
  3. Troubleshooting:
    • Swapped USB cables/ports (tested USB 2.0/3.0).
    • Verified permissions (dialout group, ls -l /dev/serial/by-id/*).
    • Checked lsusb (STM32 detected).
    • Manual serial test (cat /dev/serial/by-id/...) shows garbage output.
    • Power cycled printer/Pi, reseated cables.
Symptoms:
  • OctoPrint connects but Klipper logs mcu 'mcu': Serial connection closed / Timeout on connect.
Suspicions:
  • GD32F303 chip (not STM32F103) on 4.2.2 board?
  • Faulty 8MHz crystal or USB port?
  • Hidden config mismatch?
Request:
  • Has anyone resolved this on a 4.2.2 board with GD32F303?
  • Are there known Pi 3/Klipper quirks for Ender 3v2?
  • Debug steps I’ve missed?
Logs/Configs:
  File "/home/oscar/klipper/klippy/serialhdl.py", line 68, in _get_identify_data
    params = self.send_with_response(msg, 'identify_response')
  File "/home/oscar/klipper/klippy/serialhdl.py", line 262, in send_with_response
  File "/home/oscar/klipper/klippy/serialhdl.py", line 319, in get_response
    self.serial.raw_send_wait_ack(cmds[-1], minclock, reqclock,
  File "/home/oscar/klipper/klippy/serialhdl.py", line 254, in raw_send_wait_ack
    self._error("Serial connection closed")
  File "/home/oscar/klipper/klippy/serialhdl.py", line 61, in _error
serialhdl.error: mcu 'mcu': Serial connection closed
Ive read a lot of similar topics but none had any help that fixed things for me: Reflashed klipper (ender v3 se) and now getting mcu error - #11 by hcet14
Installing Klipper on Ender 3 - 4.2.2 Board and GD32F303 Chip
Hello @Molier !
Please upload the complete klippy.log as a file here.
klippy.log (836.9 KB)
it is full of previous attempts as well :wink:
in the end a complete redo magically fixed it. stock settings in the printer.cfg, from klipper/config/printer-creality-ender3-v2-2020.cfg at master · Klipper3d/klipper · GitHub . a fresh .bin firmware with a unique filename on a fat32, 4096 sd card. with the same settings as in the image
and it suddenly worked.
always Magic :wink:
