Problemas al intalar/arrancar klipper
Printer Model: Creality Ender 3 V2 Neo (placa 4.2.2 con GD32F303) / Creality Ender 3 S1 Pro (placa 4.2.2 con STM32F103 ) ¡Mismo problema en ambas!
MCU / Printerboard: Ender 3 V2 Neo: GD32F303 RET6 (marcado como “AUJ6387 AC2219”) → Identificado como STM32F103 en Klipper por compatibilidad. /Ender 3 S1 Pro: STM32F103 (confirmado).
Host / SBC: Raspberry Pi 4B, Raspberry Pi OS lite 64-bit.
Serial device detected:
Dekar@AyK:~ $ ls -la /dev/serial/by-id/ /dev/serial/by-path/
/dev/serial/by-id/:
total 0
drwxr-xr-x 2 root root 60 jun 4 15:28 .
drwxr-xr-x 4 root root 80 jun 4 15:28 ..
lrwxrwxrwx 1 root root 13 jun 4 15:28 usb-1a86_USB_Serial-if00-port0 → ../../ttyUSB0
/dev/serial/by-path/:
total 0
drwxr-xr-x 2 root root 80 jun 4 15:28 .
lrwxrwxrwx 1 root root 13 jun 4 15:28 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-port0 → ../../ttyUSB0
lrwxrwxrwx 1 root root 13 jun 4 15:28 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0-port0 → ../../ttyUSB1
dmesg exit:
Dekar@AyK:~ $ dmesg | tail -n 30
[ 4.093221] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 4.094645] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 4.094671] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.094678] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.094683] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.094687] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.094826] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.095049] usbcore: registered new interface driver ch341
[ 4.095081] usbserial: USB Serial support registered for ch341-uart
[ 4.143737] input: wch .cn USB2IIC_CTP_CONTROL as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1A86:E5E3.0001/input/input5
[ 4.143980] hid-multitouch 0003:1A86:E5E3.0001: input,hidraw0: USB HID v1.00 Device [wch .cn USB2IIC_CTP_CONTROL] on usb-0000:01:00.0-1.3/input0
[ 4.301556] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[ 4.302128] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
[ 4.404187] Bluetooth: hci0: BCM: chip id 107
[ 4.404940] Bluetooth: hci0: BCM: features 0x2f
[ 4.407670] Bluetooth: hci0: BCM4345C0
[ 4.407693] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[ 4.418661] Bluetooth: hci0: BCM4345C0 ‘brcm/BCM4345C0.raspberrypi,4-model-b.hcd’ Patch
[ 4.834204] Adding 524284k swap on /var/swap. Priority:-2 extents:9 across:16113664k SS
[ 4.945084] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.945101] Bluetooth: BNEP filters: protocol multicast
[ 4.945113] Bluetooth: BNEP socket layer initialized
[ 5.140258] Bluetooth: hci0: BCM: features 0x2f
[ 5.141566] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3±0190
[ 5.141572] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[ 5.159221] Bluetooth: MGMT ver 1.23
[ 5.170227] NET: Registered PF_ALG protocol family
[ 5.711601] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 5.714376] bcmgenet fd580000.ethernet eth0: Link is Down
[ 5.729946] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
klippy_E3S1Pro.log (9.2 KB)
klippy_E3V2Neo.log (77.2 KB)
As we had it before: In Englisch language please.
Also: Put your code sippets to the Preformatted Text feature of the forum editor as it is described in How-To Ask for Help
