Hello
I got a Felix 3.0 Dual which im trying to install klipper on. I’ve got everything setup, the thermistors show correct values and change if I hold my hand to the hotend. But the motors show no life at all. I based the config on the repetier configuration.h and pins.h provided by the manufacturer. I double checked the traces with a multimeter and they are the right pins. The board is running an atmega2560 with a4982 drivers.
printer.cfg (1).txt (3.0 KB)
klippy1.log.txt (2.1 MB)
