Printer Model: Ratrig v31
MCU / Printerboard: Octopus Pro + Ebb42
klippy.log not necessary
When pasting code or config snippets use the code tags </> in the menu above
Taking advantage of the fact that we are in a new year, I am going to update Klipper, I use an Octopus Pro 429, so the process is entertaining…
But my question is related to something else… I also use an Ebb42, which in its day flashed a Klipper firmware (I think).
- I have to flash a new firmware also to the Ebb42?
- What would be the process. The same one I used for the initial flaseo? Or is there a simpler one?
