Hey guys, can anyone help me figure out how to fix this problem, G28/G28 X/G28 Y/G28 Z MCU shows timer too close error no matter what, how to solve this problem?
klippy.log (1.2 MB)
klippy.log (1.2 MB)
See Timer too close
Mmmm,
The only suspicious thing that I was able to find:
serial = /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
MCU 'mcu' config: ADC_MAX=4095 BUS_PINS_i2c1=PB6,PB7 BUS_PINS_i2c1a=PB8,PB9 BUS_PINS_i2c2=PB10,PB11 BUS_PINS_spi1=PA6,PA7,PA5 BUS_PINS_spi1a=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi3=PB4,PB5,PB3 CLOCK_FREQ=72000000 MCU=stm32f103xe PWM_MAX=255 RECEIVE_WINDOW=192 RESERVE_PINS_serial=PA10,PA9 SERIAL_BAUD=250000 STATS_SUMSQ_BASE=256 STEPPER_BOTH_EDGE=1
Stats 3045.3: gcodein=0 mcu: mcu_awake=0.002 mcu_task_avg=0.000016 mcu_task_stddev=0.000010 bytes_write=17355 bytes_read=398592 bytes_retransmit=18 bytes_invalid=7 send_seq=2607 receive_seq=2607 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=72004963 heater_bed: target=0 temp=28.0 pwm=0.000 MCU: temp=37.7 Host: temp=25.0 sysload=0.50 cputime=45.434 memavail=2422140 print_time=2331.726 buffer_time=0.000 print_stall=0 extruder: target=0 temp=28.3 pwm=0.000
clocksync state: mcu_freq=72000000 last_clock=167871494748 clock_est=(3016.181 165812614913 72004963.232) min_half_rtt=0.001219 min_rtt_time=3020.125 time_avg=3016.180(845.629) clock_avg=165812614913.830(60889468461.576) pred_variance=744583.872
Dumping serial stats: bytes_write=17499 bytes_read=398624 bytes_retransmit=123 bytes_invalid=7 send_seq=2618 receive_seq=2608 retransmit_seq=2616 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0
It looks like there is an issue with data transmission during homing (bytes_retransmit).
Anyway, it is expected that you fill out the template before creating an issue.
[x] Printer Model:
[x] MCU / Printerboard:
[x] Host / SBC
[x] klippy.log
Because that can lead to some additional information, guesses.
Printer Model: MKS Robin E3D V1.1
MCU / Printerboard:Ender3 v2 (The mainboard has been replaced“MKS Robin E3D V1.1”)
Host / SBC:Redmi Note 4X(This is the Redmi Note 4X flashed with Ubuntu,The current version of the operating system is: Ubuntu 24.04.2 LTS)
klippy (1).log (19.3 KB)
Hey, buddy, help me check this out
While I’m not saying that this combination is at fault or cannot work, it would still be my first suspect.
