I am sharing a macro developed by a very helpful member here ( gaolst):
gcode_macro MEASURE_AND_SET_Z_ZERO
What this macro does is probe the bed in the center only, with a BL Touch prior to each print job; it is embedded in my START_PRINT macro (it does not create a bed mesh) .
I have it set to probe the bed 10 times then average the results, once bed and nozzle are at temp, the print begins.
I have this running on a delta printer using a BL Touch probe. I wanted this macro to verify bed height before printing because I would get Z-height drift and have to baby-step at the start of each print. this macro eliminates that. This macro can be modified to use different probe type such as a micro switch.
Here is the macro:
[gcode_macro MEASURE_AND_SET_Z_ZERO]
G90
#pre position toolhead for probing
G0 X0 Y0 Z80 F2000
PROBE
QUERY_PROBE
ALIGN_PROBE_TO_Z_OFFSET
[gcode_macro ALIGN_PROBE_TO_Z_OFFSET]
description: Query last probe result and align Z height to configured probe.z_offset
{% set z_probe = printer.probe.last_z_result|float %}
{% set z_offset = printer.configfile.settings.bltouch.z_offset|float %}
{% set z_delta = z_probe - z_offset %}
{% set z_position = printer.toolhead.position.z|float %}
{% set new_z_position = z_position - z_delta %}
{action_respond_info(
"Probe result: %.2f \n"
"Configured Z_offset: %.2f \n"
"Delta: %.2f \n"
"Current Z:%.2f \n"
"New Z:%.2f " % (
z_probe,
z_offset,
z_delta,
z_position,
new_z_position))}
G92 Z{new_z_position}
#SET_GCODE_OFFSET Z={z_delta}
Here it is referenced in my START-PRINT macro:
[gcode_macro START_PRINT]
# For PLA
{% set BED_TEMP = params.BED_TEMP|default(70)|float %}
{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(205)|float %}
M140 S{BED_TEMP}
# Use absolute coordinates
G90
# Reset the G-Code Z offset (adjust Z offset if needed)
SET_GCODE_OFFSET Z=0.0
# Home the printer
G28
# default bed mesh is PEI_BuildTak plate
BED_MESH_PROFILE LOAD=default
G1 Z20 F3000
# Wait for bed to reach temperature
M190 S{BED_TEMP}
# Set and wait for nozzle to reach temperature
M109 S{EXTRUDER_TEMP}
And here are my printer.cfg BL Touch settings (BTT Pico board):
[bltouch]
sensor_pin: ^gpio22
control_pin: gpio29
pin_move_time: 0.680
stow_on_each_sample: True
probe_with_touch_mode: False
x_offset: 0.0
y_offset: 30.0
#z_offset: 1.090
speed: 3.0
lift_speed: 3.0
samples: 10
sample_retract_dist: 4.0
samples_result: average
samples_tolerance: 0.100
If you need help setting this up, feel free to reach out to me.
