I’ve installed klipper on to my raspberry to control a skr 1.3. I followed the Configuration reference, and it seems to be working fine, but when it executes the “G1 z15.0 f6000” the z steppers stall. If I change it to “G1 z15.0 f200” it works fine. I assume that the gcode is overriding the max_z_velocity that is set to 25. This specific gcode runned fine in this printer before klipper, so I know is not it. What am I missing?
This file contains common pin mappings for the BIGTREETECH SKR V1.3
board. To use this config, the firmware should be compiled for the
LPC1768.
See docs/Config_Reference.md for a description of parameters.
[stepper_x]
step_pin: P2.2
dir_pin: !P2.6
enable_pin: !P2.1
rotation_distance: 80
endstop_pin: !P1.29 # P1.28 for X-max
position_endstop: 0
position_min: 0
position_max: 200
homing_speed: 50
full_steps_per_rotation: 400
[stepper_y]
step_pin: P0.19
dir_pin: !P0.20
enable_pin: !P2.8
endstop_pin: !P1.27 # P1.26 for Y-max
position_endstop: 0
position_min: 0
position_max: 200
homing_speed: 50
step_pin: P0.22
dir_pin: P2.11
enable_pin: !P0.21
rotation_distance: 4
endstop_pin: !P1.25 # P1.24 for Z-max
position_endstop: 0
position_max: 300
[stepper_z1]
step_pin: P0.1
dir_pin: P0.0
enable_pin: !P0.10
#endstop_pin: P1.24
#position_endstop: 0.5
#position_max: 400
step_pin: P2.13
dir_pin: P0.11
enable_pin: !P2.12
rotation_distance: 15.5
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: P2.7
sensor_pin: P0.24
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 260
max_extrude_only_distance: 50
[heater_bed]
heater_pin: P2.5
sensor_pin: P0.23
control: watermark
min_temp: 0
max_temp: 130
[fan]
pin: P2.3
serial: /dev/serial/by-id/usb-Klipper_lpc1768_1D500017E01435AE8801ED52841E00F5-if00
[printer]
kinematics: cartesian
max_velocity: 200
max_accel: 2000
max_z_velocity: 25
max_z_accel: 100
TMC2208 configuration
For TMC2208 UART
1) Remove all of the jumpers below the stepper drivers
2) Place jumpers on the red pin headers labeled XUART (XUART, YUART etc.)
[tmc2208 stepper_x]
uart_pin: P1.17
run_current: 0.800
stealthchop_threshold: 999999
[tmc2208 stepper_y]
uart_pin: P1.15
run_current: 0.800
[tmc2208 stepper_z]
uart_pin: P1.10
run_current: 0.650
[tmc2208 stepper_z1]
uart_pin: P1.1
run_current: 0.650
[tmc2208 extruder]
uart_pin: P1.8
run_current: 0.800
TMC2130 configuration
For TMC SPI
1) Place jumpers on all the red pin headers under the stepper drivers
2) Remove jumpers from the red pin headers labeled XUART (XUART, YUART etc.)
#[tmc2130 stepper_x]
#cs_pin: P1.17
#spi_software_miso_pin: P0.5
#spi_software_mosi_pin: P4.28
#spi_software_sclk_pin: P0.4
##diag1_pin: P1.29
#run_current: 0.800
#stealthchop_threshold: 999999
#[tmc2130 stepper_y]
#cs_pin: P1.15
##diag1_pin: P1.27
#run_current: 0.800
#[tmc2130 stepper_z]
#cs_pin: P1.10
##diag1_pin: P1.25
#run_current: 0.650
#[tmc2130 extruder]
#cs_pin: P1.8
##diag1_pin: P1.28
#run_current: 0.800
#[tmc2130 extruder1]
#cs_pin: P1.1
##diag1_pin: P1.26
#run_current: 0.800
EXP1 / EXP2 (display) pins
[board_pins]
aliases:
# EXP1 header
EXP1_1=P1.30, EXP1_3=P1.18, EXP1_5=P1.20, EXP1_7=P1.22, EXP1_9=,
EXP1_2=P0.28, EXP1_4=P1.19, EXP1_6=P1.21, EXP1_8=P1.23, EXP1_10=<5V>,
# EXP2 header
EXP2_1=P0.17, EXP2_3=P3.26, EXP2_5=P3.25, EXP2_7=P1.31, EXP2_9=,
EXP2_2=P0.15, EXP2_4=P0.16, EXP2_6=P0.18, EXP2_8=, EXP2_10=
# Pins EXP2_1, EXP2_6, EXP2_2 are also MISO, MOSI, SCK of bus “ssp0”
