Was working for a while, but I decided to test sensorless homing and it was acting weird. Working fine on X/Y but not Z. So I said well, probably dumb to use it there anyways, so I backed out my changes, added back a modified 2209 (pin clipped) and said okay use my mechanical endstop.
However without changing my configuration, the Z starts moving up to home (reverse from before I started messing around with sensorless (and I didn’t change the Z config in my printer, other than initially setting the endstop to a virtual of the 2209_z pin…
I’m kind of at a loss what it could be. I’ve cycled, I’ve refreshed the config file, I’ve cycled klipper etc. hmmm never cycled octoprint, but that should not matter, buuut… no change.
Anyways pertinent info.
CR10S
SKR1.4 Turbo
Bigtree 2209 drivers, X Y are complete, Z and E0 have the pin cut. X and Y sensorless is working nicely.
Klipper (can’t actually figure out what version I’m running)"
step_pin: P0.22
dir_pin: P2.11
enable_pin: !P0.21
rotation_distance: 8
endstop_pin: P1.27
#endstop_pin: tmc2209_stepper_z:virtual_endstop
position_endstop: 0.0
position_max: 400
tmc2209 stepper_z]
uart_pin: P1.1
run_current: 0.800
hold_current: 0.500
#stealthchop_threshold: 5000
#diag_pin: P1.27
#driver_SGTHRS: 70
So again try to home my Z, it starts moving up (and I don’t have my plugs reversed :)) then the system halts with the following errors: Same config that has been running for a month +, until I revamped the wiring and such.
22:35:33
Unknown command:“M420”
22:35:39
Timeout on wait for ‘tmcuart_response’ response
22:35:39
Run Current: 0.40A Hold Current: 0.40A
Klipper state: Shutdown
22:35:39
22:35:39
Unable to read tmc uart ‘stepper_z’ register IFCNT
Transition to shutdown state: Unable to read tmc uart ‘stepper_z’ register IFCNT
Dumping gcode input 7 blocks
Read 96194.934134: ‘M105\n’
Read 96199.932596: ‘M105\n’
Read 96204.933557: ‘M105\n’
Read 96212.098146: ‘M105\n’
Read 96214.935997: ‘M105\n’
Read 96219.942466: ‘M105\n’
Read 96224.943054: ‘M105\n’
