Printer Model: CUSTOM
MCU / Printerboard: LY-DP5
Host / SBC: Rpi2b
klippy (5).log (2.8 MB)
Working config/thermistor changed to incorporate new toolboard leads to no thermistor reading
My thermistor was working fine plugged into the mcu DP5 directly. Ive plugged it into a newly installed SHT36-V3 toolboard, and changed the sensor pin in my printer.cfg and regardless of whether the thermistor is plugged into the new board or not, the temperature reads -30c ish in mainsail. I’m operating the fans from the SHT36-V3 suggesting the new board is communicating correctly with the mcu.
I’ve put the schematic for the temp sensor side-by-side below from the two boards, in the hope that someone a bit more knowledgeable can spot the difference and if/how my config needs to change further.
I note that the capacitors are different sizes and that, ADC_POWER is not defined, so could be different to the 3.3v on the DP5 mcu board? It is a 12v system currently. I don’t have the j7 jumper installed, so the in-series pull-up resistance is 4.7k ohm in both cases. The gpio27 pin address is correct according to the boards drawings and example config.
#sensor_pin: HEAT0_TEMP
sensor_pin:SHT36:gpio27
sensor_type: Generic 3950
