it stopps during print and said mcu failure etc after restart it shows bed temp over 700C
if i switch the termistor with the one from hotend under octoprint the value does not change
pretty wired cause if the thermistor is broken it should change the value
Has anyone a clue for me ? has also tried a brand new thermistor same problem just got over 700C shown printer.cfg (5.3 KB)
Hi, as I said if I switch the thermistor from hotendport to bed and vice versa- the bed temperature under octoprint stays on bed temp ~700c so i don’t think it’s the thermistor itself
Could I check anything in port itself ? Or you think it’s a board defect than will i order a new one
Another thing to try might be to connect the thermistor to a different port on the board and change the config to the other port. This of course requires to have another port available. That way you can exclude that you miss something elsewhere…
Was there any work done to improve logging details of these messages?
Currently it is still a pain to determine which thermistor is failing, I was looking at the logs and still can’t determine which one is causing the problem.
