trying to implement an easy chamber-heater:
so i bought a litte AC-heater and added a relays to switch it on and off
I saw klipper setting the heater_pin to values like 30% => it should only be on or off
also it should no be switched on/off several times within 10-15-30 seconds
how do you do chamber/ enclosure heating?
dht11 sensor is not supported by clipper?
my config:
[heater_generic Chamber]
heater_pin: !PA5
max_power: 1.0
sensor_pin: PA2
smooth_time: 2.0
pwm_cycle_time: 0.3
control: watermark
max_delta: 3.0
min_temp: 0
max_temp: 100
gcode_id: C
setting gcode_id was a challenge as I have mainsail, fluidd and octoprint active and depending on A, C or X one of the web-interfaces crashed filtering temp-reports ~~
and it’s the easiest way to show the chamer-temp in TopTemp
