Printer Model: vcore 3
MCU / Printerboard Octopus Pro + Ebb42
When pasting code or config snippets use the code tags </> in the menu above
Thanks to the help you gave me in this forum, I was able to configure a Canboard, by Canbus, an Ebb42 … And works great, less some disconnections, which only happen to me before I start printing it, when I’m adjusting the TILT or preheating… I think they have to do when I send many orders to the printer, for example just turn on that hot, but it has not yet finished and I send the order is homing and tilt … In those cases, it is more likely to fail
But my post is NOT for that
This board has accelerometer included and I would like to know how to use it to adjust the resonance
Someone can tell me a guide with the steps I must follow to adjust it … I have seen that in the Wiki he explains it… Peiro if it could be I would like something more detailed … Where you will also help to understand the resulting charts
