I have wired an Arduino Nano with an adxl345 for measuring resonances, now I have the problem, that the Nano uses the same ID as my creality CR10 board. This apparently means that whichever device was connected last is getting mounted at /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0.
With my very limited Linux skills im stuck at this point. Is there a way to assign both MCUs different permament mount points?
Use /dev/serial/by-path instead of by-id. Note that this links the board to the physical USB port, so if you move the board to a different port it will have a different path. As long as you always use the same port for each board the path won’t change.
I have a lot of printers and other USB devices on this computer, so I would like to find a solution that doesn’t rely on using the same port for each device.
