Printer Model:Formbot Voron 2.4 kit build
MCU / Printerboard: BTT M8P
Host / SBC: BTT CB1
klippy.log (2.7 MB)
Has a SB2209 (RP2040) can tool head.
This printer had been up and running for ~300 hours with no issues but has started throwing this error after today. I hadn’t modified or changed anything and the error started occurring after cancelling a print while I was cleaning failed print off the nozzle.
mcu ‘EBBCan”: Unable to connect
was the first error it threw, then after some restarts it was unable to connect to the mcu at all but that seemed to be short lived.
I’m not incredibly knowledgeable on the soft/firmware side of this whole system so it was initially configured through guides and all I’ve tried is checking my hardware connections and rebuilding the firmware, using the same method as when I first set it up.
I’m a little out of my depth so any help or info gleaned from the log would be fantastic.
