Help setting up enclosure heating from cure
Printer Model: ender 3 v2
MCU / Printerboard: btt mini e3 v3
Host / SBC rpi 3b+
klippy (9).zip (2.1 MB)
im still new to klipper and im trying to get my build volume to heat up like the extruder and bed do from cura,this is my cura start code
START_PRINT EXTRUDER_TEMP={material_print_temperature_layer_0} BED_TEMP={material_bed_temperature_layer_0} enclosure_heater={build_volume_temperature}
i thing im stuck with the M141 and M191 macro but im not really sure. the enclosure heater works good from the mailsail UI just cant get it to be automated from cura
thanks
You can simply do something like:
[gcode_macro M141]
   SET_HEATER_TEMPERATURE HEATER=enclosure_heater TARGET={params.S}
[gcode_macro M191]
   TEMPERATURE_WAIT SENSOR="heater_generic enclosure_heater" MINIMUM={params.S}
thank you that works perfectly now
