Help with Clipper on ender 3 pro
Hello,
I am new at using clipper. I tried to install it and flash my ender 3 pro but I am getting the error below. I have a crealty 3D v1.1.4. I appreciate Any advise you can provide:
make flash FLASH_DEVICE=/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
Flashing out/klipper.elf.hex to /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 via avrdude
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x69
avrdude done. Thank you.
make: *** [src/avr/Makefile:34: flash] Error 1
Follow klipper/printer-creality-ender3-2018.cfg at master · Klipper3d/klipper · GitHub
if the flash command does not work, then you most likely need to flash the bootloader: Bootloaders - Klipper documentation
This is an Ender 3 pro according to the OP, so they will need to follow the instructions at the link below, unless it’s a different board. I can’t keep track of all the different Creality stuff.
Depends which information is correct :wink:
