Help with Troubleshooting: MCU timer too close error
Note the qlen 10. As described at CANBUS Troubleshooting - Klipper documentation this indicates that your txqueuelen setting is not being applied.
I recommend following the directions at CANBUS - Klipper documentation , and use the /etc/network/interfaces.d/can0 settings exactly as stated there. Restart the rpi, and then run the ip link show can0 and verify you see qlen 128 before proceeding with further tests.
TEAM! GREAT NEWS
I used the EXACT klipper suggested settings for can interface file… And for the first time, my printer booted up AND connected to the ebb36 without needing to SSH a command. I’ll be heating up the bed and home/probe everything first thing in the morning. The can network is reporting the proper txqueuelen. I removed the
pre-up ip link set can0 type can bitrate 1000000 pre-up ip link set can0 txqueuelen 1024 lines
