Homing_override issues
First of all, thank you for this incredible piece of software — it’s been transformative for my printer setup.
I’m currently running Klipper on a PrintMate3D and have encountered a practical limitation with the homing_override feature. By default, Klipper homes axes in the order X → Y → Z, but due to a clamp on my machine, this sequence can sometimes cause collisions if X homes before Y.
To fix this, I’ve added homing_override to change the sequence to Y → X → Z, which works well for full homing (G28). However, once homing_override is active, all G28 commands — including those targeting only a single axis like G28 X - now trigger the full custom homing sequence. This is problematic, especially if an object is already on the bed and a full re-home could cause a crash.
Suggestion:
It would be incredibly helpful if Klipper could restrict the homing_override block to G28 with no parameters, and fall back to Klipper’s default per-axis homing behaviour when using G28 X, G28 Z, etc.
This would allow safe single-axis homing without losing the ability to define a custom full-homing sequence.
Thanks again for all your hard work and continued support of the community.
Best regards,
Definitely changing homing_override is the right approach and by adding a bit of macro code to it like:
[homing_override]
axes: xyz
  {% set home_all = 'X' not in params and 'Y' not in params and 'Z' not in params %}
  {% if home_all or 'X' in params %}
    G28 Y # Home Y axis before X
    G28 X
  {% if 'Y' in params %}
    G28 Y
  {% if home_all or 'Z' in params %}
    G28 Z
    G1  Z10  # Lift Toolhead after Z Axis Homing
I think this will give you what you’re looking for.
Just going through the code:
  • If you just want to home the X axis - it will do the Y axis first.
  • Note that for the Y axis if statement, I don’t check for home_all because if all axes are to be homed then Y was already homed before X and there’s no reason to do it again
  • Nothing unusual about the Z axis, except I always like to move the toolhead up a few mm to make sure there’s no chance of a collision with the print surface.
Obviously, this is untested on your printer, hopefully it will do what you’re looking for.
Let us know how it works out.
That seems to solve my problem. Thanks a lot. :slight_smile:
