Moving X axis 20mm after homing
I have a filament cutter at the front of my printer I want to avoid when homing.
As my printer homes X first then Y I’m trying to find a way that after X homes is there a way for me to move X 20mm before it starts to home Y?
See Configuration reference - Klipper documentation
I did try that and and X would move 20mm and then move back to home when Y homes
What exactly did you try?
With [homing_override] you can influence the behavior of the whole homing process!
For example you can differentiate the axes and then control each as necessary - here it homes X and moves to your desired 20 mm:
[homing_override]
axes: xyz
  {% set home_all = 'X' not in params and 'Y' not in params and 'Z' not in params %}
  # Homing of X
  {% if home_all or 'X' in params %}
    G28 X
    G90
    G0 X20
  # Homing of Y
  {% if home_all or 'Y' in params %}
    G28 Y
  # Homing of Z
  {% if home_all or 'Z' in params %}
    G28 Z
You can of course outsource the actual homing commands into separate macros and call those within the [homing_override] section.
Thank you, That worked profectly
