After several tests, I managed to get it working… I don’t know why it didn’t work, but I’m posting what I did in case you see a reason.
01: I sent “lsusb” through the console and it responded with this
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 04d8:e72b Microchip Technology, Inc. Beacon RevH
Bus 001 Device 004: ID 1d50:606f OpenMoko, Inc. Geschwister Schneider CAN adapter
Bus 001 Device 006: ID 1d50:614e OpenMoko, Inc. stm32h723xx
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
CAN adapter worked
02: I have sent by console “ip -s -d link show can0”
and has returned
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 128
link/can promiscuity 0 allmulti 0 minmtu 0 maxmtu 0
can state STOPPED restart-ms 0
bitrate 1000000 sample-point 0.750
tq 62 prop-sec 5 phase-sec1 6 phase-sec2 4 sjw 2 brp 3
gs_usb: tseg1 1..16 tseg2 1..8 sjw 1..4 brp 1..1024 brp_inc 1
clock 48000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 0 0 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535 tso_max_size 65536 tso_max_segs 65535 gro_max_size 65536 parentbus usb parentdev 1-1.2:1.0
RX: bytes packets errors dropped missed mcast
0 0 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
I understood that the CAN0 network was DOWN (stopped… Why?)
03: I sent “sudo ip link set can0 up” through the console to “turn on” the CAN0 network
04: I sent “ip -s -d link show can0” again to check the status of the CAN0 network again, and returned
3: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 128
can state ERROR-ACTIVE restart-ms 0
clock 48000000
0 0 0 0 0 0
0 0 0 0 0 0
This time the status is UP
I have been able to access Fluidd…
But… Why would he have stopped?
