Printer Model: Sovol SV04
MCU / Printerboard: stm32f103xe
…I’m using my IDEX in copy mode. Somehow, the bed mesh is only being done on half of the bed. How do I make the bed mesh cover the second half?
Do you think it would make sense?
Usually you do disable bed mesh with copy/mirror mode and start with a thicker 1st layer.
Why would it only take one side of the mesh? A smarter mesh compensation would average between the two nozzles printing at the sams time…
Average won’t have any advantage.
If you have a point of z = -0.1 on one side and z = 0.1 on the other side, the average is 0, but too high on the first and too low on the other side.
I beg to differ.
In this case you’re describing, the layer thickness of 0.2 can compensate for both sides of the print whereas having a meshing for one side only guarantees the other side to fail.
That was an example. Yo usually go with a bit more for the first layer.
The chances are high
