How to modify printer.toolhead.homed_axes in macro?
Printer Model: selfmade core xy (2 servos, 4 steppers)
MCU / Printerboard: Raspberry Pi 4b + 2x BigTreeTech SKR 1.3
klippy.log (96.2 KB)
I just started to dig a little bit deeper into Klipper and macro programming. I want to use a special G28 homing procedure with some extra clearance moves. Here I discovered some problems with the printer.toolhead.homed_axes flag:
To move before homing with an active kinematic transformation I need to use
SET_KINEMATIC_POSITION
Although I e.g. only want moving in Z direction (3 steppers), using this command leads to setting all axes as homed.
Before creating a feature request to home only those axes entered as parameter I first tried to unset the internal homed flag. printer.toolhead.homed_axes is read-only so something like
{% set printer.toolhead.homed_axes = "x" %} # invalid
is not valid.
When using M18 or M84 Klipper does not support using a kinematic axis like
M84 X # parameter without effect
M18 or M84 disable all drives and clear all home flags.
Using
SET_STEPPER_ENABLE STEPPER=stepper_x ENABLE=0
also does not affects the homed flag as this command does not interacts with the kinematic model.
So, after all these tests I am still not able to force a wanted printer.toolhead.homed_axes flag. I need this for a save behavior when re-implementing e.g. G28 Y
Any comments, ideas or help?
Thanks
Thosch
+1 I noticed a similar issue. Did you find a good workaround for this?
See
Thank you for the detailed reply! :smile:
What details are you missing? If a longer answer helps:
  • There is currently no workaround
  • The feature is WIP and not yet available, but you can cherry-pick this PR if you want.
