Unable to Home Printer after Latest Klipper Update
Printer Model: RatRig V-Core 3.1
MCU / Printerboard: BTT Octopus V1.1 (F446)
Host / SBC: Raspberry Pi 4B/
klippy.log (160.2 KB)
I updated Klipper on my printer today as I saw there were some commits to it on 01/21/2025. Since then, I am unable to home the printer without first spoofing the X, Y, and Z Coordinates. The error message I receive, no matter whether I try to home all axes or a single axis is, Must home axis first: 0.000 0.000 7.000 [0.000].
I’ve posted the screenshot below of the console and also attached the klippy log file.
This error message makes no sense… How can I home an axis before homing it?
Is there a way for me to roll back to a stable version of klipper?
The SET_CENTER_KINEMATIC_POSITION is a custom macro that sets the axes kinematic position to 1/2 the max printer dimensions, essentially spoofing the printer into thinking the toolhead is at X=150, Y=150, Z=150. Here’s the macro:
[gcode_macro SET_CENTER_KINEMATIC_POSITION]
description: FOR DEBUGGING PURPOSES ONLY. Sets the internal printer kinematic state to the center of all axes regardless of actual physical position.
	RESPOND MSG="WARNING: ONLY USE SET_CENTER_KINEMATIC_POSITION FOR DEBUGGING PURPOSES. YOU'RE OVERRIDING THE INTERNAL POSITIONING STATE OF THE PRINTER. PROCEED WITH CAUTION AND DO A PROPER G28 WHEN DONE."
	SET_GCODE_VARIABLE MACRO=MAYBE_HOME VARIABLE=is_kinematic_position_overriden VALUE=True
	SET_KINEMATIC_POSITION X={printer.toolhead.axis_maximum.x / 2} Y={printer.toolhead.axis_maximum.y / 2} Z={printer.toolhead.axis_maximum.z / 2}
I used KIAUH to roll back 3 commits and now homing works. Once the three commits pertaining to homing were rolled back things worked just fine. These are the commits I rolled back:
I’m not Github savvy, so not sure how to report this as an issue on the klipper Github. Any advice?
You are running a highly modified Klipper with unknown extensions.
Probably there is something with klippy/extras/ratos_homing.py
I tested those patches before the merge and they work.
btw, I also have RatRig.
If you are able to reproduce it on vanilla Klipper - you can definitely report an issue.
Thanks. I figured it had to do with the RatRig version of klipper. The ratos_homing.py extension is the RatOS homing extension that combines both the Klipper homing_override and safe_z_home sections into one. I’ve raised an issue on the RatOS Github for this.
