I keep losing my printer.cfg
Printer Model: RatRig vcore3 400mm
MCU / Printerboard: Octopus Pro
Host / SBC: Raspberry Pi 4 2Gb
klippy (2) (3).log (7.0 MB)
hello guys, I need help: Every now and then randomly when I turn the printer back on I find the printer.cfg completely empty, and every time I lose my configuration.
The printer is a 400mm ratrig kit, initially I thought it was Ratos the problem but now I have reinstalled Mainsailos completely from scratch over and over again, but nothing every now and then I find the printer.cg empty.
I tried everything, changed SD card and reinstalled everything several times but nothing, checked the directories and everything is ok.
I don’t know what to do anymore and I’m going crazy.
I’m thinking of replacing the raspberry but first I wanted to know your opinion.
I haven’t found any solutions online.
Help me please!
Thanks
Curious. I have no f… idea.
Good luck, hcet14
toolboard: temp=34.7 sysload=0.59 cputime=2.622 memavail=3389764 print_time=39.706 buffer_time=0.000 print_stall=0 extruder: target=280 temp=273.6 pwm=0.646
It still seems like an SD card issue or an SD communication issue.
Ideally, you want to know to work, a new good SD card to check that.
A somewhat simple way to achieve something similar is to flash SD card and check the image.
Depending on your qualification you can do that either with dd or format, write a large enough file, and check checksum before and after.
If the card is healthy, well, there can be an issue with RPI and/or RPI power.
I can’t guess what can be done here, maybe clean contacts with some isopropyl alcohol and check the voltages and power.
Btw, Also you may want to just use the official raspberry pi imager and the latest clean/lite image, IIRC it does check the SD card after flash.
Instead of different prebuilded images.
Hope that helps.
In perfect world some sort of filesystem with CoW and checksums will be used for SD cards.
