SD Card in Raspi broken
Printer Model: Mega X
MCU / Printerboard: SKR 1.4 Turbo
I’ve been running Klipper on my Anycubic for months without issues. Unfortunately, when I cecked something with the Raspi I broke the SD Card :frowning:
Will I have to install everything from scratch on now…?
BR
Michael
I would try your SD Card in your PC. Is it readable? If yes, save everything. Do you use a camera?
No, it is broken into pieces…:grimacing:
Sadly yes - if you do not have a backup that is stored elsewhere.
As long as you backed up your printer.cfg and other config files on your PC or somewhere off the sd card, you just need to reinstall Klipper on a new card and copy over the config files. If you don’t have a backup, you start all the way at the beginning.
Really sorry for your bad luck!
Just from curiosity, how the hell did you manage to break an SD card into pieces?
Good luck with your printer, hcet14
Rush paired with too little awareness paired with an idiotic design of the SD slot on the Raspberry. I din’t get the card out before pushing the Raspi back in the original housing, when it obviously got bent and sligtly cracked. During next boot-up it smelled of ‘burning electronics’ - and thr SD was terminated.
So you are not a code cracker but a card cracker?
Often I forgot the card a well when putting back the Pi but did not break anything yet.
Regularly back up at least your config files!
:joy: Yep, seems so :joy: So I will now di everything again…:roll_eyes:
