i was updating when the Ras4 reboot .. i don’t know y .. not it can’'t reboot .. Agreen led flashes 7 times .. it means .. the kernal image not foung … is there any possible way to use WinScp to modify this situation .. i memorry card is running i used winscp to check it .. it read it as boot Fill out above information and in all cases attach yourklippy.logfile. Pasting yourprinter.cfgis not needed When pasting code or config snippetsusethe code tags</>in the menu above
Most likely, your SD card has been corrupted.
My advice would be to set up your system again. You could of course play around and try to fix the problem, but you’ll probably waste more time and have a good chance of failing than if you start from scratch.
I Belive the same here … thnx Bro… you helped me a lot …so if u planning to visit Egypt … plz contact me ill help … staying and to have good time ISA
thnx bro
i have followed it sadly …
1-Started with fluid imager on SD card using raspb imager
2-return SD card to rasp and by wifi connecting PUTTY and installing Kiauh !!
i followed the same link u shared with me … this how i do it all the previous times before!!!
Now i ve setup mainsail !! … and it went good !! with the same procedure i don’t know y … it seems to better one
the only problem now that it cann’t connect with the printer … ive flashed klippy.bin with the stepps as usual … ive attached the klppy file log klippy (2).log (326.1 KB)
What is the output of ls /dev/serial/by-id/*?
Did you make sure to have set the correct build options during make menuconfig? In doubt, do the firmware build again and reflash the board.
