Printer Model: sunlu s8 with ender 4.2.7 mainboard and factory spliced z cable
MCU / Printerboard: 4.2.7 klippy.log klippy (14).log (90.6 KB)]
Fill out above information and in all cases attach yourklippy.logfile. Pasting yourprinter.cfgis not needed When pasting code or config snippetsusethe code tags</>in the menu above
flashed the sd card twice same problem.
used the same file to flash another sd card last week and it worked.
This error message generally means that the Klipper Host cannot establish any connection with the board (as if the board was not even connected). Could be:
Not correctly build firmware, e.g. wrong settings in make menuconfig
Not flashed correctly
Hardware issue with respect to the USB port / cable
tried multiple “known good” usb’s
multiple “known good” sc cards and flashes
not sure what firmware build is but the other three ender 4.2.7’s that i have cloned this way work.
the baord is new but unknown
how can i test the board?
suddenly i can connect but there are no config files and i cant drag and drop anything into the list klippy (19).log (277.3 KB) moonraker (3).log (79.7 KB)
